garf Posted April 16 Share Posted April 16 Greeting, I have a question on setting the orientation. Say I have 3 orientations like the following. When I want to have mix orientation, why I can only have Mix #1 and #2? How to make the setting so that I can have say Mix #1 and #3 or Mix #2 and #3? Thanks in advance for advices. Link to comment Share on other sites More sharing options...
Stéphane Metz Posted April 17 Share Posted April 17 Dear @garf, Indeed, it is only possible to mix orientations 1 and 2. This is a current software limitation. If you want to mix orientations 1 and 3 for example, you will have to switch orientation 3 to orientation 2. FYI, we are currently working on version 8 which will remove a lot of this kind of limitation. Regards, S. Metz Link to comment Share on other sites More sharing options...
garf Posted April 17 Author Share Posted April 17 10 hours ago, Stéphane Metz said: Dear @garf, Indeed, it is only possible to mix orientations 1 and 2. This is a current software limitation. If you want to mix orientations 1 and 3 for example, you will have to switch orientation 3 to orientation 2. FYI, we are currently working on version 8 which will remove a lot of this kind of limitation. Regards, S. Metz I see.. thanks for informing. actually if I combined orientation 2 and 3 via manage orientation, what would be the impact on the shading loss? thanks Link to comment Share on other sites More sharing options...
