garf Posted March 10, 2023 Posted March 10, 2023 Hi All, can check with you how to do the setting to display my module layout in Pvsyst report? thanks
Lazare Fesnien Posted March 13, 2023 Posted March 13, 2023 Dear Garf, To do this, please click on "PRINT" : Then check the box "include module layout on final report" : Regards,
garf Posted March 14, 2023 Author Posted March 14, 2023 20 hours ago, Lazare Fesnien said: Dear Garf, To do this, please click on "PRINT" : Then check the box "include module layout on final report" : Regards, Thanks for enlighten me. if you don't mine, can I also check with you is it possible to zoom the near shading picture of the PV module section? thanks in advance
Gabriel Giacomelli Posted October 30 Posted October 30 On 3/13/2023 at 7:55 AM, Lazare Fesnien said: Dear Garf, To do this, please click on "PRINT" : Then check the box "include module layout on final report" : Regards, Hello I performed the procedure described above. On the module layout definition screen, all modules are positioned and assigned. On the module layout printing screen, the option to choose the orientation is not enabled. In the final simulation report, the module layout is empty. I would be grateful if someone could help me with this problem.
Hizir Apaydin Posted November 5 Posted November 5 On 10/30/2024 at 2:18 PM, Gabriel Giacomelli said: Hello I performed the procedure described above. On the module layout definition screen, all modules are positioned and assigned. On the module layout printing screen, the option to choose the orientation is not enabled. In the final simulation report, the module layout is empty. I would be grateful if someone could help me with this problem. Dear Gabriel, No tables appear on the graph in the module layout printing screen. To resolve this, try zooming out or repositioning the scene to make them visible. Once adjusted, they should display correctly in the report. If the issue persists, please export your project (via the main menu: File > Export project) and send it to support@pvsyst.com for assistance. Best regards.
