Import project from another Designer
What is the easiest way to import a PVsyst project from a 3rd party designer
- He has sent me the .VC# file and meteo file.
I realized i need a .PRJ file and create my own under the same file name, this allowed me to access the .VC# files with the same name, but when opened I am missing the inverter file and Module file.
If I had their .PRJ file would this give me the same error?
What files will I need to import their exact model without manually editing any parameters?
thanks
When exporting a project you shoud use the option "Files" / "Export Projects/Components" in the main menu (your 3rd party designer should have done this).
This ensures that all files involved in the project (i.e. .PRJ, *.VCi, .MET file, and components file if they are custom defined) are indeed present.
And you can import this project using "Files" / "Export Projects/Components".
  • 8 months later...
Dear Andre,
I am running V6.22 and, when exporting projects (using the export project tool), if I open the ZIP file generated, I can only see the ".PRJ" and the ".met" files.
Is this normal?
Shouldn't be exported the components and the variants also ?
Thank you,
Esteban
Yes in principle the ZIP file contains the project *.PRJ, the meteo file *.MET, the variants *.VCi, and the components which are not present in the original database.
Please check that your project contains indeed sohttp://forum.pvsyst.com/index.php?sid=9a56d2e74fa0a16b827fcf5adc6152afme saved calculation versions.
