Brian S Posted September 8, 2021 Posted September 8, 2021 Hi I'm trying to run my analysis using bi-facial modules set onto a ground profile. Once I have established my shading scene the model gives me the following error message 'Your PV system is not suited for the bifacial 2D model computation:' but fails to explain why. The shading scene is correct and PVsyst has validated it, and is a direct copy of the built system I am modelling this on. Is anyone else having this issue? Any suggestions? Thanks in advance.
HLubke Posted September 8, 2021 Posted September 8, 2021 Hi Brian!Did you configure the bifaciality details in the system section (button above the PV-module selection list) or did you just select the PV-modules with bifacial functionality?Regards!
Brian S Posted September 8, 2021 Author Posted September 8, 2021 Thanks for the reply. I have configured it correctly, and have modelled bifacial modules several times before without issue. I think I have solved the issue though. My tables were inserted by auto-filling my table zone. I edited a couple of the tables manually after this to reduce the size of the tables. When I checked the details of the tables that I hadn't changed the settings had shifted in the size definitions from 'by modules' to 'by sensitive areas'. I changed the setting manually back to 'by modules' and had to adjust the number of modules per table again as they seemed to default to a number that I hadn't specified. That seemed to fix the issue. Luckily my system is reasonably small (2MWp) as anything much bigger would have taken a long time to manually change. Not sure exactly what the underlying issue was but changing this setting seemed to resolve it. Cheers!
