MarVF6 Posted May 13, 2021 Share Posted May 13, 2021 Hello,I would like to do a batch simulation of an east-west-systems I created in "Near Shading" I had to characterize two different orientations with different azimuth (one to the east, one to the west). Unfortunately it seems impossible to change the tilt of these orientation with the batch simulation? Is there any chance to do so or do you have an idea to fix the problem? Thank you for your help,best regards,MarVF Link to comment Share on other sites More sharing options...
kjs55 Posted February 25, 2023 Share Posted February 25, 2023 (edited) Hello, I saw this post at the same time as the other. In the PVsyst help documentation for batch mode [1], it presently says: """Plane orientation - Modify tilt, azimuth, or shed characteristics (pitch, electrical effect) if unlimited sheds defined.""" [1] https://www.pvsyst.com/help/batch_mode.htm Of course, I defer to the @PVsyst team, but I propose this edit: """Plane orientation - Modify tilt and azimuth for fixed tilt orientation (presently limited to a single orientation) plus shed characteristics (pitch, electrical effect) for unlimited sheds and certain other characteristics (Nb. of trackers, backtracking, phi limits) for tracking PV arrays.""" Edited February 25, 2023 by kjs55 Move position of linked URL Link to comment Share on other sites More sharing options...
kjs55 Posted February 25, 2023 Share Posted February 25, 2023 (edited) Edit: Even simpler option, b/c there's already a section on "3D shadings parameter": Existing language: """Plane orientation - Modify tilt, azimuth, or shed characteristics (pitch, electrical effect) if unlimited sheds defined.""" [1] https://www.pvsyst.com/help/batch_mode.htm New proposed edit: """Plane orientation - Modify tilt and azimuth for fixed tilt orientation (presently limited to a single orientation) plus shed characteristics (pitch, electrical effect) if unlimited sheds defined.""" Edited February 25, 2023 by kjs55 Add word "language" Link to comment Share on other sites More sharing options...
Michele Oliosi Posted February 27, 2023 Share Posted February 27, 2023 Thanks @kjs55 indeed that makes more sense. @MarVF6 indeed at the moment there is no native way to modify several orientations through the batch mode. In the medium long term we should be able to develop the feature along this direction, but to my knowledge it will take some time. Link to comment Share on other sites More sharing options...
