joubert Posted October 1, 2019 Share Posted October 1, 2019 HiIs it possible to get a single hourly output file for multiple (25) years by:using the same meteo data for each yearusing a specified degradation percentage in the aging setting under detailed lossesspecifying a grid limitation that is applicable every yearThank you Link to comment Share on other sites More sharing options...
André Mermoud Posted October 9, 2019 Share Posted October 9, 2019 You can define different conditions from simulation to simulation using the Batch mode. Each simulation may produce an Hourly CSV file. But these resulting hourly CSV files will be independent. If you want to gather them in one only file you have to do that manually. Link to comment Share on other sites More sharing options...
mohaned Posted February 15 Share Posted February 15 I am running ageing simulation, i need to produce hourly files, for a few of the simulation years, but they are not produced. is that possible? i ticked the generate report and output file tabs, and i get a pdf report, but no hourly file. Link to comment Share on other sites More sharing options...
Agnes Bridel Posted February 15 Share Posted February 15 The hourly output file generation is available if this option is activated in the original simulation. This can be done through “Advanced simulation > Output file”. When this option is activated, you can run the multi-year simulation again in aging tool and the output files will be in the “UserHourly” folder of your workspace. Link to comment Share on other sites More sharing options...
