1. Total voltage mismatch loss =
Mismatch loss (voltage drop due to wiring resistance)
+ Mismatch loss (voltage due to PV array temperature variation)
+ Mismatch loss (Specified voltage distribution tool)
e.g. 0.05%+0.51%+0.34%
2. What is the use of option "wires and results"? Is it total result?
I don't see how you have evaluated these loss percentages.
By the way the mismatch losses are not cumulative, as each of them implies a displacement of the Pmpp on the I/V curve.
You have a detailed tool for studying the mismatch between strings: In the system dialog, "Detailed Losses > Module quality-LID-Mismatch", you can press "detailed study".
Here you can press F1 for a description of the Mismatch problematics.
Usually the mismatch between strings (in voltage) is extremely low.
