I recently updated my software to V6.67. I've imported a .pan and .ond file for my panel and inverters, respectively. I go to project -> grid system definition and can find the module & inverter I'm looking for. I select them, pick my numbers of strings etc. and click ok. I even ran a simulation, no problem.
The software is having a hard time retaining my component definitions, though. When I go to revise the configuration, I get the error message "No component available now on the market for this manufacturer" and it erases my previous selections. I have to re-select my module/inverter each time.
If I don't reselect, and hit "cancel" exit out of the grid system definition window, my "system" button turns red and I get the following error: Error while reading hte PV module "xxxx.ond" : File not found You will have to define another one in "System" definitions!
I open the definitions again and now I can't select my module; it said my module was invalid. So I close out and try to reopen, and now it's found the module exactly as I had defined it before.
I'm not sure what's going on it's just being very buggy every time I try to open the grid system definition window to make any changes. Note, this started after I went through my detailed losses and made some changes to match my project specifics. Help!
  • 7 months later...
I am having the same issue, with a system with 5 sub-arrays. I hit "all modules" rather than "available now", but PVsyst keeps changing this and then giving the same error message you got.
  • 2 months later...
Tagging on to this thread, V6.66 has the same error for imported OND files. These files have been provided by the manufacturer.
Every time I save and switch the variant, it gives me this problem.
