YoanD Posted November 10, 2017 Posted November 10, 2017 Hello,Our 6.6.6 PVsyst is totally freezing after we selected "use optimizers" in the "system" window of a project...Is it an issue you already encountered ?We are trying to simulate the use of optimizers with small PV modules (30W) which are connected in parallele. (approx. 6 PV modules per optimizers)Thank youYoanD
André Mermoud Posted November 16, 2017 Posted November 16, 2017 This has been corrected for the version 6.67. When defining your "system" configuration, please avoid defining several sub-arrays from the let-top corner control. After having defined your first sub-array, you can create a second one (copy of the first one) by right-clicking on the sub-array headre labels.
rouge26 Posted May 15, 2018 Posted May 15, 2018 I am currently using version 6.68 and still having this issue with SolarEdge optimizers. As soon as I select one type of optimizer the software freezes. I cannot go around this even trying different order of selecting inverters/optimizers. Is there a way to make this work?Thanks.
André Mermoud Posted June 2, 2018 Posted June 2, 2018 Yes there was also a big problem (freezing) when you defined SolarEdge inverters along with not-SolarEdge ones in other sub-arrays. There was not a straightforward solution. This has been treated in the version 6.69 by a serious update of the SolarEdge Management.
