gonecrawfishin Posted August 31, 2017 Posted August 31, 2017 Hi all,Is there a way to use TMY data at a user defined site? I have imported my TMY data, but I can't seem to make it available to my site. I can make a site specific to that TMY data, though I worry that the latitude is too far off from my actual site. Maybe it would be inappropriate to use TMY at a different site and it's not possible to do in PVsyst... advice?
dtarin Posted August 31, 2017 Posted August 31, 2017 Where is your TMY data from? Maybe you can:1) change the coordinates in the tmy data file to match the site you want to use. The import into PVsyst as usual. When you load your project, you will have your desired site selected, and then you can switch to your MET file with the desired tmy data2) create the site, then use the ASCII input method to import your tmy data, selecting the site you want to be associated to it 3) change the project settings and increase the distance allowed for met files to be used from the site
gonecrawfishin Posted September 1, 2017 Author Posted September 1, 2017 That was it! I was using NREL TMY3s, but changing that distance value in the preferences made my files available. Thank you!
