l.krusephoenixsolar Posted September 19, 2012 Posted September 19, 2012 Hello,I tried to import a helios project into PVsyst.And I got the following error message: "Warning:The orientation of all planes in the shading scene should be identical. (Here 4 different orientations). (Only with grid systems, if two orientations please choose "Heterogeneous Fields" in the orientation definition parameter)."Please also see attachmentI don't really understand what this means and how it can be solved. Actually all modules have the same tilt angle an are orietated towards south.Maybe somenone can help me?Thanks in advance!!!
André Mermoud Posted September 29, 2012 Posted September 29, 2012 When defining and exiting a 3D shading scene, PVsyst checks that it is compatible with the rest of your system. In your case: - You have not yet defined the system (modules and inverters)- In the "Orientation" part you should define a tilt of 22° and an azimuth of around -26°NB: when developing a new system (calculation version) in PVsyst, you are advised to always begin by a basic system, and then add the complications step by step.The definition of the 3D scene is a secondary step, it should be done after the definition of the "Orientation" and the "System" parts.
dereksolar Posted November 30, 2012 Posted November 30, 2012 Hello Andre,I am having the same issue with PVsyst and Helios 3D.I get a message that says:"Warning: The orientation of all planes in the shading scene should be identical. (Here 5 different orientations). (Only with grid systems, if two orientations please choose "Heterogeneous Fields" in the orientation definition parameter)."After I match the shading areas and adjust the tilt/azimuth, I still get this message.Any other suggestions for trouble shooting?Thanks.Derek
DanielE Posted March 27, 2013 Posted March 27, 2013 Hello Derek,Try the following settings - it should work then.
André Mermoud Posted April 10, 2013 Posted April 10, 2013 And in the version 6, these limit angles are defined within the project (button "Albedo - Settings"). In the version 6, you have a tool for analysing the spread of orientations in Helios3D constructions, and the program will choose the orientation average as calculation basis.
