Search the Community
Showing results for tags 'module layout tool'.
Hello, I can't do my module layout with the selected PV module, having this error (image1) "The PV module 'name' is defined as "in length" with 2 cells in parallel. It cannot be used with the Module Layout calculation." In the module settings, it is defined as "in width" and not in length. Here are the informations about the module (image2) Any solution ? Thanks
I would like to report following bug: Please see on the enclosed picture, field “Table choice”. It shows Table Row#66 Col#3, but on the drawing, it shows Row#36 Col#3 (hidden by comment) and in yellow Table Row#66 Col#3, Module depending on module and Inverter #6 String #8 or #depending on position. I believe that shown on the drawing is wrong (Row#36 Col#3). Here is Col# right, but that is not the rule. Additionally in the yellow box Inverter# do not correspond to the list of inverters MPPTs and strings. I see this as serious inconsistency in program markings and suggest to be corrected.
- 1 reply
- bug
- module layout tool
(and 1 more)
Tagged with:
