        Julien Rosener
                Posts19
Everything posted by Julien Rosener
	So it looks this issue is not related to the fact you updated PVsyst from 6.3.0 to 6.3.1. Maybe it is due to changes on file access rights ? To prove that, I would suggest to copy paste the whole PVsyst6_Data directory from the network path to a local path. Then you will have to reference it via File >> Workspace >> Switch... After restarting PVsyst, please check if you are able to access all your projects for example.
	Hi Jen, We did not touch anything about file reading in 6.3.1, it might probably be a side effect from something else. May I ask you to install 6.3.0 again to check if you are able to access the files please ? http://download.pvsyst.com/index.php?page=download&prod=true&key=PVsyst-prod/bin/PVsyst6_3_0_setup.msi
	Hi Jen, Indeed this looks strange. Did you try to restart your computer (maybe the network mapping was failing) and also PVsyst and try again ? I just checked with a workspace at a network address and it looks to work as before. What I would also suggest is to go explicitly in your network workspace using the Windows file explorer before using PVsyst: indeed (at least on my machine), if I do not go manually on it, it is not loaded for most of the application which are referencing this place. Bests, Julien.
	On some systems with big display resolutions Windows tries to scale what is displayed by the program: in this case the PVsyst's report could also be displayed with too big fonts. The solution is to disable the scaling on high DPI screens (Properties on PVsyst's shortcut). Playing with other options could also help.
	Michele, You are fully right, this file is a Sketchup plugin which will be used to generate a JSON file describing a PVsyst 3D model. Anyway as you said, it is still under development: that's why there is no way to use this file at the moment. We are working on that and we also planned something similar for Autocad. Stay tuned for the next releases.
	There are few reason why activating PVsyst failed. One of them could be because PVsyst needs a web access to activate your license. If the web access does not work (security policies), there is an external way to activate PVsyst. Just follow the steps in the video: it shows you how to go on the PVsyst portal (on a machine which has a web access) to activate and download your license file. [youtube=um1JdqVbG68]
	It looks like the 6.1.9 is already installed. Could you check if the directory "C:\Program Files (x86)\PVsyst6.1.9" exists please ?
	There is already a forum post about that: http://forum.pvsyst.com/viewtopic.php?f=25&t=1283 However, we have to deeply modify PVsyst to distribute calculation on all cores. We are currently discussing about this topic.
	Description If you already used and saved data under PVsyst 6 on a old computer and would like to switch to a new computer, there are 2 things to do: - transfer your license (if you have one) - export data from the old computer and import them on the new one Export data from old computer - Plug a USB key in the old computer. - Start PVsyst. - Go to main menu >> File >> Workspace >> Export... - Set the path to the USB key to export data and switch on "Compress exported workspace", then click on Export This procedure will create file PVsyst_ExtData.zip containing all your PVsyst data on the USB key. Import data on the new computer - Plug the USB key in the new computer. - Start PVsyst and accept the default options when asking where to find a data workspace. - Go to main menu >> File >> Workspace >> Import... - Set the path of the exported zip file PVsyst_ExtData.zip (on the USB key) - Set a new workspace path, for example C:\Users\\PVsyst_Import, then click on Import
	It is all your user data (basically the directory C:\Users\\PVsyst6_Data). You can manage your workspace (import/export/switch to) from Main menu >> Files >> Workspace. I need to check if running on 4 cores increase the speed even we are not using parallel execution. One of the best way to help us to reproduce something on our test machines, is to export and give us the full workspace: in that case we will be in the same software environment. No idea. I would also expect the same value on both dialogs.
	Indeed this looks strange. I would suggest to export/import the full workspace to have exactly the same user data in both computers (if it was not already the case). If the difference is still there, we are interested to get your data/workspace to try to reproduce slow simulations on our testing machines. There are definitely not a lot of file system I/O in PVsyst. Indeed it should not affect the speed. Julien.
	Dear Adnan, Basically we encourage users to execute simulation going from very basic project to more complex one: following that you do not have to execute a lot of "big" simulations. That's how it should be used, but we know it is not always possible. Indeed there are a lot of calculations, however the processor usage is quite small: this is because there are a few other things that could explain why it takes time. Most of the time, allocating memory (RAM) and accessing files takes much more time that the computing itself. That's why "increasing the processor usage" will only happen if we are able to reduce drastically accesses to RAM and/or file system. Doing some parallel computing could also be an idea to improve simulations. This is definitely not an easy job but there are still things to improve. This is in our TODO list, stay tuned. Bests regards, Julien.
	When trying to install PVsyst 6.x on Windows 8, an error message from the SmartScreen service could be displayed: "Windows Smartscreen prevented an unrecognized app from starting. Running this app might put your PC at risk." Do not panic, if you downloaded PVsyst from http://www.pvsyst.com, PVsyst installer does not contain any viruses or malwares. PVsyst is a regular application, it beneficiates of an official "signature" delivered by an independent organism. To get rid of this message you have to turn off the Windows Smartscreen service: * Open up the classic Control panel >> System and Security link >> Action Center. * Expand the security list and look for the Windows SmartScreen >> Change settings. * Turn off the Windows SmartScreen Filter and validate. Then you can start again installing PVsyst.
	Description: When starting PVsyst an error message "Access violation at adress....." appears. So PVsyst can not start. Explanation: This is most probably due to the default project (the last used project) which is corrupted: indeed if something crash when writing the project, the project file (or related files) could be corrupted. PVsyst can not read corrupted files. For convenience, when PVsyst is starting it automatically loads the default project: if it is corrupted, it ends with this error message. Solutions: 1. One way is to identify the project file which is corrupted and delete it (projects default directory is: C:\Users\\PVsyst6_Data\Projects). Then restarting PVsyst will work again. 2. Another way is to remove the default project value from the settings file of PVsyst. PVsyst will start without loading any existing project. For that:* Open with an editor like Notepad the file C:\Users\\AppData\Local\PVsyst6\\Admin\PVsyst6.ini (if you do not see the AppData folder you have to show hidden files and directories in the option panel of Windows Explorer). * Remove value of the keys Project and Site, you should get something like that: Project= Site= * Save the file and start PVsyst
	We indeed had a very short term issue on our servers. Please apologize for that.
	In PVsyst 6 the license activation is partly based on the "Windows Product ID" of the host computer. However the Windows Product ID changes after the Windows registration (PVsyst will not accept the license and start in trial or demo mode). So please register your Windows copy before activating PVsyst. But if it happened (you registered Windows after activating PVsyst), please contact us at admin@pvsyst.com.
	Since PVsyst 6.05 there is a major change in installation strategy. The installation changed from a "per-user" to a "per-machine" method. It means that every users of the machine will see the PVsyst shortcut. It was asked by several people. The bad news is that the installer can not "see" the previous version because of this change. So after you installed version 6.05 you will still see the previous version on your system. You actually have to uninstall it manually. This is an easy procedure and it does not affect your PVsyst data which could be used in 6.05 To uninstall the previous version: - Windows main menu >> Configuration Panel >> Uninstall a program - Right click on "PVsyst" in version 6.04 (or a previous one) and "Uninstall" - Accept uninstallation warnings. Notice that this issue only happen once: future releases won't be affected, the installer will properly uninstall the previous version.
	Solution #1 When PVsyst is starting Windows checks if it is coming from PVsyst SA to ensure that this is an authentic copy of the software. This should guarantee that PVsyst is virus and malware free. If this check is failing a pop up is displayed: "The application can not start because it is not signed by PVsyst SA." If you downloaded PVsyst from http://www.pvsyst.com, the error is probably appearing because you are using an old Windows, which does not contain our security partner's certificate. Please follow this procedure to update your Windows certificate list: - In Windows, start menu >> Control panel >> Add or remove program >> Add/Remove Windows component - check "Update Root certificates" - click OK. - then restart the computer. Solution #2 It looks like sometimes, asking Windows to update certificates is not enough: it does not install the correct certificates. The other solution is to install certificates manually. Here is the procedure. 1.Download these 2 certificates: - https://certs.godaddy.com/repository/gd-class2-root.crt - https://certs.godaddy.com/repository/gd_intermediate.crt 2. Install these 2 certificates, so for each of them: - Double click on it - "Install certificate" - "Next", "Next",... (keep the default options) until the end. Start PVsyst again. Solution #3 If you are using Windows 7 and still encountering this issue, the following may be useful. First of all, you need to be logged in as an Administrator on the computer. Download the two following certificates : https://certs.godaddy.com/repository/gdroot-g2.crt https://certs.godaddy.com/repository/sfroot-g2.crt For each certificate : 1. Double-click the file 2. Click on Install certificate 3. Click on Next 4. Select Place all certificates in the following store, click Browse, check Show physical stores, select Trusted publishers > Local computer 5. Click OK, click Next, click Terminate Try running PVsyst again, and if adding both certificates still doesn't fix it, try the following steps : 1. Click Start, click Start Search, type mmc, and then press ENTER. 2. On the File menu, click Add/Remove Snap-in. 3. Under Available snap-ins, click Local Group Policy Object Editor, click Add, select the computer whose local Group Policy object (GPO) you want to edit, and then click Finish. 4. Click OK. 4. In the console tree, go to Local Computer Policy, Computer Configuration, Windows Settings, Security Settings, and then click Public Key Policies. 5. Double-click Certificate Path Validation Settings, and then click the Stores tab. 6. Select the Define these policy settings check box. 7. Under Per user certificate stores, clear the Allow user trusted root CAs to be used to validate certificates and Allow users to trust peer trust certificates check boxes. 8. Under Root certificate stores, select the Enterprise and third-party certification authorities radio, and then click OK to apply the new settings. And then try to run PVsyst again.
