JamesLenton
Daily generation profile Irregularities
JamesLenton replied to JamesLenton's topic in Problems / Bugs
Hi Auriane, I have since made change to that variant, and when re-running it I am not seeing anything as extreme as the situation I posted above. However, there are still some very fast drops from almost max power to very low power (but not zero). I have sent across the project files to PVsyst support email anyway for you to investigate. Kind regards, James. -
Hi Linda, We tried PVGIS and Meteonorm and saw similar anomalies on different days also. Weather data imported from those 2 sources shouldn't have missing data however? James. -
Hello, The cause of the drop appears to be the irradiation. Do you know why this could occur, it seems unrealistic. -
Hello, Please can you help explain why irregularities like the one shown in the image attached occur in PVsyst? In this instance power drops from 15 MW to 0 MW in 30 minutes, mid-day in the summer. To me this seems impossible, even with partial cloud cover. Could be a result of poor weather data, however I experience similar things with Meteonorm and PVGIS.
Array of trackers 3D scene defining N-S & E-W slopes
JamesLenton replied to JamesLenton's topic in How-to
Hi Michele, Thank you for the response. The solutions for running the simulation with high tilted axis worked, as did making fixed tilt array first with E-W slope before transforming to trackers. I suppose there will be inaccuracy in the bifacial modelling if we are using sloped trackers but PVsyst assumes a flat axis, no other way to solve that so no worries. Best, James. -
Hello, We are trying to model single axis trackers on different slopes: - from +5 to -5 degrees N-S - from +5 to -5 degrees E-W The 'axis tilt' value for trackers can be changed to model N-S slopes in an array of trackers in the 3D scene. However, when we do a message appears saying "tracker axis must be horizonal for PVsyst to model the bifacial gain". Is there no way around this currently? Secondly, there doesn't seem to be a method of inputting a E-W (tracker to tracker) slope for the array of trackers. Please could you point me in the right direction if there is a way of doing this? Kind regards, James.
Thats very helpful, thanks again! James.
I have just double checked and the studies were carried out at maximum power. So that would represent STC, meaning taking it as a % of TIC is then the correct input. Thank you.
Hello Michele, The losses I am referring to are the losses in the power systems study, which are given to us in kW. I have this for the DC ohmic losses, AC cable losses from inverter to transformer, AC cable losses from transformer to PoC and for the transformers. To enter the cable losses into PVsyst, I divided each by the total installed capacity to get a percentage and then entered this as the % loss at STC with the correct wire sizes. Is this the best way to go about it? Kind regards, James.
Hello, I am looking to include estimated losses from a power systems study to make my PVsyst report more accurate. In the report the total losses are given in kW, to get this to a % losses at STC, what power should I divide this by? Total installed capacity (DC) - this is what seems right AC inverter capacity Export capacity (less than inverter capacity in this case) I can't find the answer on the PVsyst help pages, hope you can help me. Kind regards, James.
