Hossam
Everything posted by Hossam
I wanted to ask what paremeter identifies the degradation of the PV modules due to the rise of module temperature (thermal stresses)? Does the ageing tool take into consideration the module temperature? And does the ageing tool provide average degradation per year differently for different module typesetting? @Michele Oliosi
- aging tool
- temperature
(and 1 more)
Tagged with:
@Michele Oliosi
Hello, I am using PVsyst to simulate a PV plant in Egypt. I tried to import NASA SSE meteorological data. However, the wind velocity values are all 0 m/s. What is the reason behind this? Thank you
How can I find the absorption coefficient of the PV module in order to be used in the thermal parameter?
Possible error in the Performance Ratio´s help section
Hossam replied to allanfisica's topic in Suggestions
@Michele Oliosi Do you have any updates regarding this issue? Thanks in advance. -
Yes @Michele Oliosi I can show you the results of one single iteration in four different locations, you will find a constant difference in the annual average values. Weather Corrected PR - PR = 0.003 The four attachements shows the results of running the simulations with the same system inputs but the only difference is the weather data. -
@Michele Oliosi I always get a fixed difference in the simulation results. When I change the location to different cities, the difference between PR and WCPR is 0.003 -
@Michele Oliosi Hope this message finds you well. I have the same issue and Can you please explain to me how the weather-corrected PR is calculated in PVsyst and is it fixed or not yet because I get a fixed difference between PR and weather-corrected PR of 0.003 -
Thermal Parameter Calculation using Meteo Data (Ambient Temperature)
Hossam replied to Hossam's topic in Meteo data
If I export the excel file using only the meteo data then If I import it again, it will be recognized as a new meteo file in PVsyst? Thanks in advance -
@Michele Oliosi Please tell me the answer of the first question. Thanks in avance. -
Can you explain what is the 8760 ? Please attach media. Thank you so much. -
@Michele Oliosi -
This means PVsyst recognizes the time where there is no irradiance and then does not calculate the thermal losses unless the irradiance presence is provided in the hourly values table. Is this right? Secondly, How can I export the meteonorm 8.1 data used in my simulation as I need to edit only the ambient temperature. Thank you -
This means the losses are only calculated using the hourly temperature values only in the presence of irradiance or throught the day (24 hours)? -
Does it include the ambient temperatures at night in the simulation of thermal losses? -
The meteonorm 8.1 database has hourly values of ambient temperature. Does PVsyst calculate the Cell temperature using the ambient temperature value at the specific time during the simulation or it uses the monthly average for all days? I mean does it calculate the cell temperature only during daylight or it merges all heat transfer throughout the year, day and night.
What is the optimization technique (algorithm) used in PVsyst?
This means that the average is taken for hourly values even during night ?
Hello, I want to know the ambient temperature used in the monthly meteo data is which monthly average? Average of High Daily Temperatures Average of Low Daily Temperatures Average of Mean Daily Temperatures Thanks in advance
