jonipa
1 Follower
  1. @Michele Oliosi would you please be able to comment on this? Thanks
  2. Hi, I am getting the following error while trying to get PVGIS TMY data from the weather data import: Anyone with the same problem? Thanks.
  3. @Michele Oliosi @André Mermoud your help is appreciated. Thank you.
  4. When defining the loss fraction, PVSyst mentions in the documentation: And when going to the definition of PNom of the inverter: When it says "without temperature correction", does this mean the ohmnic loss fraction to input at PNom(Inv) should be calculated at its maximum power instead of at its nominal power? As an example, it would mean calculating the ohmnic loss at 320kW (Pnom of inverter at 40ºC) or 352kW (Pmax of inverter that happens at 30ºC).
  5. Hello, has this already been implemented in PVSyst 8? If so, how can we check the associated inverter derating loss due to high Vdc (Vmpp)?
  6. How is the GlobInc parameter calculated in theses cases of large tilt spread? Is it the incident radiation on the average tilt plane? Is the average tilt plane calculated as a weighted average?
  7. Hello, no comments on this anyone?
  8. Hello, Taking a look to the project simulation losses graph and main results with which the PR is calculated some questions arise regarding GlobInc parameter. While in the main resutls table I get a yearly value of 2483,9 kWh/m2. The losses graph shows a value of 1849+34.4%=2485 kWh/m2. I understand it could be assumed as the same value though it is not exact. But the main question involves the next losses on the graph such as far and near shadings, reflection, diffuse, etc. They are applied AFTER defining GlobInc value but in reality (on-site) what we will be measuring as GlobInc will be a value in which shading losses, reflection, diffuse irradiance, etc. are already applied. To my understanding this has a big effect on the Performance Ratio value given by PVSyst as, in my opinion, the value of radiation used in the PR formula should be closer to the "Effective irradiation on collectors" value rather than "Global incident in coll. plane". Could anyone share their thoughts on this? Thank you!
  9. I would also like to follow up this topic. It is still not implemented in PVSyst and can lead to errors on yield results, specially in high oversized DC generators.
  10. Had to set it to horizontal N-S tracker and just run the simulation without computing the shading table before. The shading table was computed while simulating and could get the results report. But after closing the results window the error pops up again.
  11. Also tried so but when modifying PVSyst needs to recompute the shading factor table. Then "field type" changes to "Tracking, tilted axis automatically" again. Still haven´t found a solution.
  12. Thank you Dtarin, Tried to do so. Succeeded for 5m pitch trackers but when entering the 3D scene for 6m pitch I get the following error. Any thoughts on what could be happening?
  13. Thank you very much, Then I guess "Module warranty" values have nothing to do in the simulation? There is no need to input them and only using "PV module agging parameters" box is enough?
  14. Hello, I am currently analyzing a 1P trackers' PV plant. One side of the plant is configured with 6m pitch while other uses 5m pitch. As I enter the 3D scene using these two tracker separation I get the following error as PVSyst is not able to compute such scenario: In blue and yellow the two different pitch we have: Anyone some advise on how to deal in this case? Thanks a lot!
  15. Hello, Recently I've been wondering how to enter PV module aging parameters right as information online is a little confusing. I would really appreciate some light on this topic to try to answer the following: How should we enter "PV module aging parameters"? Where to get the info from? Is it right to enter "Module warranty" parameters using the specified in de module's datasheet? Are these parameters used in any kind of way in the simulation? Thank you in advance!
