Hello, With lower PV production due to ageing modules, it seems reasonable to see less overload losses.- 9 replies
- losses
- inverter clipping
(and 3 more)
It is expected for plant/inverter clipping to decrease as system capacity degrades.- 9 replies
- losses
- inverter clipping
(and 3 more)
Hi Linda, Thank you. After ensuring that the "Simulation for Year" is from 1 to 25, I get results as per the below attachment. This now shows reduction in production, but somehow inverter losses (columns starting with "IL_") also decrease with each year, which is not what we had expected. Could I have missed something? Many thanks!- 9 replies
- losses
- inverter clipping
(and 3 more)
You define the year in the batch parameter csv file. As in the video tutorial un minute 7. Now indeed it seems like you are not varying any of the parameters and simulate the same project 25 times.- 9 replies
- losses
- inverter clipping
(and 3 more)
Hi Linda, Yes. Even when I change the Year No. to "25" in the "Aging" section within the "Detailed Losses", it seems to produce results related to that specific year as many times as there are rows. How do I ensure that each row is for each year, and not one year repeated across multiple rows (as attached)? Your assistance is really appreciated.- 9 replies
- losses
- inverter clipping
(and 3 more)
Hi, It seams like you have set all the simulations for year 1. In the 15th column "Simulation Year"- 9 replies
- losses
- inverter clipping
(and 3 more)
Hi, Linda. When following the steps in the second video, I cannot seem to find the approach to simulating data for 25 separate, consecutive years. My resulting batch CSV shows the exact same outputs for all inputs, as per the attachment below: Please may you advise on where I went wrong or how I can edit inputs to show independent losses and resulting parameters to show the inverter behaviour over a 25-year period. Thanks again.- 9 replies
- losses
- inverter clipping
(and 3 more)
Thank you for this feedback, Linda.- 9 replies
- losses
- inverter clipping
(and 3 more)
Hi, You find information of how to define the ageing in the following tutorial: The Batch mode is described in the following tutorial:- 9 replies
- losses
- inverter clipping
(and 3 more)
- 9 replies
- losses
- inverter clipping
(and 3 more)
Bieng joined the community
Elise joined the community
