  2. Hello, Indeed the PVsyst simulation is hourly based, so any sub-hourly phenomenon has to be averaged. This includes the weather data or self-consumption. The main reason for this limitation is that we currently consider that Perez’s transposition model is not well calibrated for sub-hourly data (EUPVSEC 2023). Sub-hourly simulation should be available in PVSyst 8.1, but the release date is not yet defined (it will be after 2025). Nonetheless, we included a sub-hourly clipping correction in PVsyst 8.0, allowing the simulation to consider sub-hourly irradiance fluctuation for clipping (EUPVSEC 2024) You can refer to the dedicated section in our help page for more information. The last option is to use the so-called pseudo-subhourly simulation. The idea is to run n hourly simulations (in your case n = 60min/15min -> 4 ) then recombine the results. You can find a PDF tutorial about the whole process in our website: pseudo sub-hourly simulation This process can even be automated if you have a PVsyst CLI licence. You can find an application of pseudo-subhourly simulation using PVsyst CLI in python in the help Please note that pseudo sub-hourly simulation cannot be used with energy storage systems. Best regards,
  3. Dear Renan, Thank you for reaching out. Even if you got the information message The license file "C:\ProgramData\PVsystCLI\PVsystCLI.lic" is missing. You can run "lic-activate" command to activate your license. the simulation should perform if you are still in TRIAL mode. Could you please export and send us your PVsystCLI log files to support@pvsyst.com (you can generate PVsystCLI logs with the command "PVsystCLI export-logs") Best regards.
  4. I was testing PVsystCLI normally, and suddenly the following error started to appear: The license file "C:\ProgramData\PVsystCLI\PVsystCLI.lic" is missing. You can run "lic-activate" command to activate your license. When I run the command PVsystCLI lic-info, I get the following information: The license file "C:\ProgramData\PVsystCLI\PVsystCLI.lic" is missing. You can run "lic-activate" command to activate your license. Status: TRIAL Remaining days: 17 Remaining executions: 208 Host ID: HARDDISK=0000_0000_0000_0001_8CE3_8E05_00AE_DC3E., ETHERNET=0A0027000004||70A8D3D028D0||72A8D3D028CF||70A8D3D028CF||70A8D3D028D3||B44506AB2282, WIN_PRODUCT_ID=00342-43291-73682-AAOEM, BIOS=752V6R3 It clearly says that my Trial license is still valid, but the CLI doesn’t run any simulations — it just stops with the “license file missing” error. I didn’t change anything in my system configuration, and this issue appeared suddenly. What should I do to make PVsystCLI work again during the trial period?
  5. Yesterday
  6. Hello, I would like to ask, since I know it's not possible to do it for now, are you planning to add i some time possibility to simulate results in 15 minutes intervals, not only in hourly system like right now we have? If yes, then when we could expect to see it implemented in PVSyst, more or less at least? I'm asking mostly in terms of hourly data we can generate in csv. file but of course also about basic reports. We are getting more and more questions regarding this topic from our clients and banks when looking for proper financing for our projects and it would be good to know if there is something we can hope for in the future.
  7. Hello, The available area in the Pre-sizing help in the System window, serves as a guide for a first order of magnitude of how many panels you can fit on a dedicated surface. This tool take only the size of the panels into consideration (not the spacing between the panels or a pitch). If no 3D scene is defined, no configuration other than what is defined in the system and orientation window is considered (no shadings). Defining a 3D scene with the surrounding shading elements, include electrical shading definition etc. will more accurately simulate the system. You find a tutorial for the 3D tool in the following link: Another potential important parameter for a vertical system would be the reflection on the ground. For a monofacial system, this is discussed in the following forum page:
  8. Hi, From the information you provided, this behavior does not seem normal indeed. The 1st graph looks ok, having 5.8% losses due to the grid limitation with 320kVa installed and 250kVa does not strike me as unusual. The fact is has been lowered to almost nothing in the second case is strange. I tried to reproduce your test case, but the results I obtain are correct. Please contact support@pvsyst.com and share your project so we can have a better look at what's happening.
  9. You can add a battery in your database from scratch by using "Databases => Batteries => New". But you are strongly advised to choose a similar battery in the database, modify its parameters according to your own component datasheets, and save this as a new battery. For defining an hybrid system, you should choose the button "Storage" in the project's dialog, and probably choose the option "Self consumption" for your case.
  10. I would like to inquire about the correct procedure for simulating PV façade installations in PVsyst. I have specified the available façade area and set the tilt angle to 90°, but I am uncertain how the software interprets this configuration. Does PVsyst arrange the panels vertically on a single flat surface (side by side), or are they positioned one behind another? Additionally, is there an alternative or more accurate method to simulate façade-mounted PV systems in PVsyst?
  11. No, in the present time PVsyst doesn't consider the charging of the battery from the grid.
  12. We update the database using the requests of the manufacturers, and publish it with each new release of PVsyst. We can't of course follow all the new products of all manufacturers in the world. We don't want to include data without the acknowledgement of the manufacturer. Nevertheless you can easily create your own components by yourself. The easiest way is to choose a similar existing device in the database, modify its parameters according to the manufacturer's datasheets, and save it under a new name, therefore creating a new file in your database. You have a tutorial for that on youtube: https://www.youtube.com/c/PVsystTutos. The inverter database already includes microinverters.
  13. Hi. How can I run a simulation using a microinverter? Also, how can I include a microinverter in the database? Thank you.
  14. Last week
  15. Dear PVSYST Support, I have a question about the grid limitation in PVSYST. Indeed, in my simulation, I put the grid limitation at 250 kVA this way with AC ohmic loss =3% And the result is -5.8% of unused energy. It seems very huge and the impact on the productible is very strong. I did the same simulation with 0% Ohmic loss, and the result of unused energy is -0.1% How is calculated the Unused energy ? It seems that the more you have ohmic loss, the more you have Unused energy due to grid limitation. It's not logical for me. Do you have more informations about this please ? Thanks a lot Sincerely Mickaël BLEIN
  16. Abeer
    Hybrid System
  17. We update the database using the requests of the manufacturers, and publish it with each new release of PVsyst. We can't of course follow all the new products of all manufacturers in the world. We don't want to include data without the acknowledgement of the manufacturer. Nevertheless you can easily create your own components by yourself. The easiest way is to choose a similar existing device in the database, modify its parameters according to the manufacturer's datasheets, and save it under a new name, therefore creating a new file in your database. You have a tutorial for that on youtube: https://www.youtube.com/c/PVsystTutos.
  18. Hello I need the PAN file for this modules Lumina-SS9-66HD-71ON and what it's name on the pvsyst database. Additionally, I need the OND files for this inverters GOODWE GW50KS-MT , GW15K-ET AND GW50K-ET-10.
  19. There is a limit for maximum output power on the inverter, but since you are adding more strings to the inverter, it means that the inverter will hold onto maximum power generation for longer amounts of time. Essentially you are increasing the time for maximum operation resulting in overall more solar generation.
  20. Sandro
    Hybrid systems
  21. Yes this is what I meant ! However, the differences seem to be small, I do not think they would account for the transposition difference. Another possibility that could exacerbate the effect of small GHI differences could be if DHI was not included in the file or not used at import ? Is there a chance you could send the weather data files (MET) or the raw data over to support@pvsyst.com? This would make the analysis a bit simpler.
  22. Hello Michele - I had a similar thought so I compared the GHI total (from the weather input files). Is this what you were meaning? It could be possible this is all due to the rounding effect noted by the satellite weather data provider. 1-minute total: 1759.7 kW/m^2 60-minute total: 1758.8 kW/m^2 I also looked at it this way to see if there were any obvious patterns:
  23. Glad to help ! I see, however I still fail to see the purpose of this request, sorry. If the inverter clips at a given time, this means that at that time the PV production reaches the clipping threshold at that time. If you model the PV production based on the measured data (not from a TMY), the clipping time should at least roughly correspond to the reality. Same thing with the module temperature, if you were to model using the real historical weather data, the temperature of the modules, measured and simulated, should at least roughly match. Let us know if I missed something about your intentions with the simulation.
  24. Dear JStief, This is puzzling, especially because PVsyst will average data to 1-hour steps anyway, meaning that the modeling should be identical. The first thing that springs to mind is that the 1-min, 5-min, and 60-min files are not simply related by averaging. In other words, if you average the 1-minute data, you won't obtain the 60-min data. Is there a chance to check that ?
  25. Hi, Indeed the maximum number of rectangles is limited to 100. However, in most cases—even for large-scale projects—each table typically contains only a few strings, so this limitation normally is not issue. For example, if each table includes four twin half-cell panels arranged in portrait orientation, and each row of panels in the table corresponds to a single string, then the table would require eight rectangles in width (x-direction). Could you please clarify how the system layout is defined in your example? You can find more details about the partition model in the following help page https://www.pvsyst.com/help/project-design/shadings/electrical-shadings-module-strings/index.html?h=partition
  26. Hi Michael, First of all, thank you for your response. Unfortunately, in both cases, the system has already been installed, and I don’t have the option to replace the equipment. It might be worth considering adding this function in future versions.
  27. The Problem in PVSyst 7.4: When designing a large-scale power plant, we run into a big problem in the "Near Shading" tab. The software does not allow us to put more than 100 for the "Nb. rectangles in width (X)". This is a major limitation for large layouts. We know that the "Module Layout" tool is the accurate way to model things, but it is too slow and not practical for very big systems of several megawatts. It also doesn't fix the core problem we have with the partition limit in the first step.
  28. Hello - I recently ran a test on the same variant using 60-minute, 15-minute, and 1-minute TGY (typical GHI year) data from a satellite weather provider. The 15-minute Egrid was less than 60-minute (due to sub-hourly clipping), but (surprisingly) the 1-minute result was the highest out of the three. This was due to higher Global Incident in coll. plane (POA, plane of array). The top line GHI varied by one - due to rounding differences per the satellite provider explanation. I'm hoping to better understand why the pvsyst simulation would have had this result. I reviewed the PhiAng and the hourly tracking angles are identical. See image below of the three different weather file runs' waterfalls. Thank you 1min, 15min, 60min pdf.pdf
