Markmax6 joined the community
- 3 replies
- tarray
- simulation
nabdulgalil joined the community
Yvano started following Electric layout
- 3 replies
- tarray
- simulation
JaSc joined the community
dlartin joined the community
Letan591 joined the community
zakari91 joined the community
Electrical Mismatch Losses
Thanks! -
Sure, that's how we handled the generic mismatch problem in the past, but it would be nice if it just worked, taking advantage of the CAD system including specific details.
