sebastian_samson joined the community
Santiago joined the community
surronbike02 joined the community
PatrickDoyle joined the community
Katie joined the community
Sorry I don't really understand what you want to. The Ohmic losses can be defined in the Detailed losses window - Last week
Stephan Sartor joined the community
solsken energy llp joined the community
bab joined the community
Aya_SoranoAI joined the community
Hi, this is strange. NS axis trackers (whether 3D scene or using the “unlimited trackers” optimization) should work without issue. Can you send your project (use the export button in the project window to generate a zip archive with all necessary files) over to support@pvsyst.com ? Or share a snapshot of the disposition of your 3D scene. This will allow us to look into it further.
