nurul joined the community
Maitha S joined the community
Mbelli Njah Fongha joined the community
kidsbikes34 joined the community
Are you saying that the (front-side) near shading loss would be lower if i modelled a bifacial system because these systems are more precisely modelled or defined, even though the near shading losses happen before any bifacial modelling in the loss diagram (and should be independent of whether the system is mono or bifacial)? -
piterpal1988 joined the community
PabloCliment joined the community
Sorry, the albedo shading factor should be *~65% and *~48% during these times, not sure what happened there -
Thanks dtarin, it worked! -
