Do I have to used Monthly normalizations in order to input the daily hourly profile for every month? Seems like they still using the same Load Profile and change the values for each month based on how many days in the month. I want to input the profile for every month without them connecting like this. - Today
Suphanat joined the community
zak joined the community
Jakson joined the community
cson joined the community
Sanjoy Pal joined the community
