thanks! -
Qitter joined the community
Diana joined the community
JacksonCarroll joined the community
jianke1985 joined the community
i am gettin this stupid frustrating error that my orientation do not match by 180 degress with polygonal PV on my shadow scene even if they correspond and i not know how to solve. for be specific i have different orientation one is tilt 10 azimuth -52 one is tilt 10 azimuth -63 one is tilt 10 azimuth 30 , now i get ok with tilt 10 azimuth -52 but the other give error if they are ok . as you can see the orientation is ok it match why it give error
I see ! I just remembered that in this version (7.2) there is a bug for trackers. In the object management window, the number of partitions is not affected to the right variable. It is connected to the size of the partitions instead which in turn makes it not work. Please use option 3 or update the PVsyst version.
You are right, it was a typo, my version 7.2. Do you have any idea why my shading scene in method one does not show proper shading animation? I don't even see the dotted lines that show partitioning is done, but the shading factor table looks good for a backtracking which is 0 everywhere. I afraid that it produces zero because shading is not working at all and not because of correct partitioning.
Michele Oliosi started following Partitioning
Hi, There is no object management window in PVsyst 6, so I assume you are using a more recent version. Which version are you using ? I have tried to see if solution 1 had a bug in version 8.0.19, but everything works fine. You are probably correct that solution 2 may have an issue sometimes. The zone tool is rather old and sometimes misbehaves. Solutions 1 and 3 should be equivalent.
Dharani joined the community
Akmal joined the community
