James Barry joined the community
xander joined the community
abdullah ali joined the community
matthewGrant joined the community
sundance-juliet joined the community
MOHAMMED ALHAJJ joined the community
MariusPostolachi joined the community
Kkp joined the community
Hello Michele - I had a similar thought so I compared the GHI total (from the weather input files). Is this what you were meaning? It could be possible this is all due to the rounding effect noted by the satellite weather data provider. 1-minute total: 1759.7 kW/m^2 60-minute total: 1758.8 kW/m^2 I also looked at it this way to see if there were any obvious patterns: - Earlier
Dear JStief, This is puzzling, especially because PVsyst will average data to 1-hour steps anyway, meaning that the modeling should be identical. The first thing that springs to mind is that the 1-min, 5-min, and 60-min files are not simply related by averaging. In other words, if you average the 1-minute data, you won't obtain the 60-min data. Is there a chance to check that ?
