- 3 replies
- tarray
- simulation
nabdulgalil joined the community
Yvano started following Electric layout
- 3 replies
- tarray
- simulation
JaSc joined the community
dlartin joined the community
Letan591 joined the community
zakari91 joined the community
Electrical Mismatch Losses
Thanks! -
Steve Dean joined the community
Sure, that's how we handled the generic mismatch problem in the past, but it would be nice if it just worked, taking advantage of the CAD system including specific details.
