  1. Yesterday
  2. Hi is it possible to set or simulate that during 8-10AM the plant will priotize to charge the battery and not inject to grid?
  3. Last week
  4. Unfortunately, it’s not possible to import a PVsyst project created in version 8.0.4 into version 7.4.8. PVsyst files are only compatible from lower to higher versions, not the other way around. To open the project, you would need to use PVsyst version 8
  5. Sounds good, I look forward to the results. I would assume that the DIRINT or DIRINDEX model is the best bet, unless you would like to delve into Engerer...
  6. Still present in 8.0.16, don't see mention of correction in 8.0.17 or 8.0.18 release notes.
  7. Hello, In the current version, PVsyst simulation is hourly based. Thus any sub-hourly phenomenon has to be averaged. Sub-hourly simulation should be available in PVsyst 8.1, but the release date is not yet defined (Normally in the beginning of 2026). Nonetheless, we included a sub-hourly clipping correction in PVsyst 8.0, allowing the simulation to consider sub-hourly irradiance fluctuation for clipping. You can refer to the dedicated section in our help page for more information. The last option is to use the so-called pseudo-subhourly simulation. The idea is to run n hourly simulations (in your case n = 60min/30min -> 2 ) then recombine the results. You can find a PDF tutorial about the whole process in our website: Pseudo sub-hourly Simulation Kind regards
  8. Dear Bommu, When you open PVsyst, you can see an information box at the bottom of the main window that indicates the remaining validity period of your license. Additionally, you can configure your email subscriptions in your Web Account at https://www.pvsyst.com/shop/ to receive notifications when your license is about to expire. Best regards,
  9. I am trying to import a project file from 8.0.4 into PVsyst but I have version 7.4.8, is there a way this can be done? I keep getting error messages that say there are conversion errors and unrecognized enum values. Any help would be greatly appreciated, thanks!
  10. We update the database using the requests of the manufacturers, and publish it with each new release of PVsyst. We can't of course follow all the new products of all manufacturers in the world. We don't want to include data without the acknowledgement of the manufacturer. Nevertheless you can easily create your own components by yourself. The easiest way is to choose a similar existing device in the database, modify its parameters according to the manufacturer's datasheets, and save it under a new name, therefore creating a new file in your database. You have a tutorial for that on youtube: https://www.youtube.com/c/PVsystTutos.
  11. Dear Ziad, Can you also try this feature: Tools → Automatic altitude (see below)? Select your entire table first, then enable this feature. On the right, try setting 1 meter or more, choose Lowest point, and click Set automatic altitude. Let me know if this solves your issue. Regards,
  12. Hi, I would like to check if there is any existing feature in the software that provides a reminder or pop-up notification during login when the license is nearing expiry (e.g., 10 days or 1 day before). Currently, I do not see any such notification, which could lead to missed renewals and potential service disruption. Could you please confirm if this functionality is available or guide me on how to enable it? Thank you
  13. Hello everyone, I’m looking for PVsyst data files (.PAN) for different PV panel models from various manufacturers. If anyone can share these files or provide a reliable download source, I would really appreciate it. Thanks in advance
  14. Hello , I have a cad file containing contour lines and points of a site, I extracted the data from the cad file into a csv file containing X,Y,Z coordinates of all the points in it and imported it into PVsyst scene as a ground object , but the problem is that when I place the PV tables over it ,some of them are not placed properly
  15. Again, if you change any figure for the battery, it WILL impact your simulation. If you change the number of cells or the number of blocks or the number of racks, the battery characteristics will be impacted (voltage for the components in series, capacity for the components in parallel). The only issue I can see is the display of the number of UNITS in the grid storage window, which is not changed as it should when you change the number of blocks in the battery component. Now, if you have this values in your report (10*2 Units) but did not set 10 racks in series and 2 racks in parallel, please contact us at support@pvsyst.com with your project so we can have a better look at what's happening.
  16. In the DC circuit (array of strings), the total wire length is indeed the lenght of the whole loop (this si mentioned just below "Please specify the total wire length for each circuit. " For the AC circuit, this is the line length (distance between devices).
  17. Actually it counts in simulation. 20 batteries.
  18. I think you misunderstood what I meant. You can any number of cells, modules and racks and it will be taken into account during the simulation. Only this specific figure displayed here is false. But that's only for display, so it won't impact your simulation.
  19. Dear PVsyst Team, I would like to clarify the wire length definition used in PVsyst. Could you please confirm whether the following wire length inputs should be entered as **one-way length** or **two-way length**? 1. DC Circuit: String module connections / Main box to inverter 2. AC Circuit: Length Inverter to injection Thank you very much for your support. Best Regards, NaK
  20. Earlier
  21. Hello, We are starting to think about the question of simulating TANDEM solar cells in PVsyst, but unfortunately for the moment it is not possible. The behaviour of the two absorbers with temperature and solar spectrum is not trivial and we need to implement a few models to describe it. Though, I believe the case of 4T (both cells connected in parallel) can be more easily approximated than the 2T case (both cells connected in series), as voltage mismatches create usually less power losses than current mismatches. I will give here an attempt to set up PVsyst to approximate a 4T Tandem behaviour in the present version of the software (8.0). But bearin mind that this is a very preliminary approach and require more testing. 1) Create two .Pan files, one to represent the top cell, one to represent the bottom cell, as if they were measured independently. This way you set up the one diode parameters for each cell. Use the same number of cells, modules dimensions etc... 2) Create a system with two subarrays, one with each .Pan files, with same number of panels connected in series and number of strings in both. Connect them to a same inverter and use the power sharing feature. You will not be able to connect the two subarrays to a single MPPT here, so at this stage we are neglecting the voltage mismatch (see next step). 3) Advanced losses / Module Quality LID Mismatch / Strings Voltage Mismatch: You can add here a general percentage to represent the loss of power due to the mismatch. To evaluate this one, you can use PVsyst specific tools > Electrical Behaviour of PV Array > Heterogeneous array. Here you can select your two .PAN files and open the I/V graphs. It will show you the percentage loss due to the mismatch between both modules for a given time of the day and date. Vary a bit those one and you will notice that this percentage is almost constant, as voltage mismatch should behave. Report this number in the Advanced losses. 4) Thermal model: We also need to tweak PVsyst regular parameters. With our setup, PVsyst will see two independent panels with low efficiency (~<15%), and therefore calculate that they are dissipating a lot of energy into heat. Which is not correct since in reality we have a single device with high efficiency (>30%), so more electricity, less heat. We need therefore to adapt the coefficients of the thermal model (https://www.pvsyst.com/help/project-design/array-and-system-losses/array-thermal-losses/index.html#thermal-model) According to the equation of the thermal model Tcell=Tamb+(Alpha⋅Ginc⋅(1−Effic))/U we could correct the model by using a different U value to compensate for the wrong (1-Effic) term. In my example (assuming single cells efficiency at ~15% and Tandem at about ~30%), the corrected value would become U_corr = U * (1-0.15) / (1-0.3) = U * 1.21. So in the case of open rack, instead of using the values of Uc = 29 W/m2/K, use something slightly larger Uc_corr = 35 W/m2/K. This will lower the losses of 1-2%. 5) Spectral correction: Unfortunately, I haven't reflected yet on how to adapt the spectral correction for the Tandem case. I think this cannot be guessed and of course the behaviour will be different than crystalline silicon. But you should keep in mind that it might be an import factor that we ignored too here! Please do not hesitate to comment on the approach. And as said above, we are reflecting on what model to implement in the future for dealing with 2T and 4T tandem devices, so any input would be useful for us : )
  22. So it means that I cannt change amount of batteries as i whish. i have o tell to my customer thas don't warry this project is with bugs ?
  23. Dear LPeterson, Thanks for reporting the issue. We managed to reproduce it and we are working on a fix to address it. In the meantime I can only advise to roll back to a previous version of PVsyst to import weather data like you mentioned doing. Best regards, Eric
  24. Hello, I have the tandem cell details, the bottom and the top. How can I simulate it as a 4T connection? can I do it separately?
  25. This all seems like a lot more work than having the project export include a SIT file. Why can't we just have that? Normally, when passing an export file to someone else, we copy the SIT file from the data directory and send that as well. It's not a good use of time and is easy to forget.
  26. Hello all, I am working on a sensitivity analysis for a grid-connected hybrid system (PV + BESS) and I'm running into an issue with the "Batch mode" (parametric simulation). My goal is to run a simulation where I vary the Number of batteries in parallel to find the optimal storage capacity. The Problem is that I can set the N_bat_parallel as a batch variable, but when the simulation runs, it fails with a warning for each new step. The error is: The problem seems to be one of parameter co-dependency. The batch mode correctly changes the number of batteries, but it does not automatically update the associated "Charging max. power" and "Discharging max. power" parameters in the storage definition. This creates an invalid system. For example, the simulation tries to run a case with 20 batteries but still uses the original charging power that I defined for 10 batteries, leading to an impossible C-rate and the current limitation error. Is there a way to solve this within the batch simulation tool? Ideally, I would like to define the PCharge_max parameter as a function of the batch variable (e.g., PCharge_max = N_bat_parallel* P_charge_per_battery; This would be possible if charge and discharge battery parameters were simply available in the batch mode. I am aware that I can manually create multiple "variants" and adjust both the number of batteries and the charging power in each one. However, this is very time-consuming and defeats the purpose of the automated batch mode for a wide sensitivity analysis. Is there a built-in feature or a known workaround to manage these co-dependent parameters in a single batch run? Thank you for any advice you can provide. Best regards, Alberto
  27. Hello, Thanks for your message. In theory the installation of 8.0.x should not uninstall 7.4 version. Maybe it comes from the automatic process updating PVsyst, is it done with a specific software ? To validate that you can also try to install manually a 8.0.x adn check whether it uninstall your 7.4 Regards, Laurent
