Hello, In general, far shading affects the entire PV field uniformly — at any given moment, the sun is or is not visible on the field. As a result, it can potentially reduce the impact of near shading, since far shading may occur during times when near shading would otherwise be present, typically when the sun is low on the horizon. - Today
Bipin joined the community
Mark Russell joined the community
Paul Gaudry joined the community
Hussain Hamid joined the community
Leowen346 joined the community
Osamu joined the community
