Auriane Canesse started following Daily generation profile Irregularities
Hello James, If the dip in irradiance is not due to missing data, I would need your files to look into this issue in more detail. Could you send your project at support@pvsyst.com ? Auriane - Today
Kadam joined the community
it worked. thanks for your quick reply. -
Kanagavel K started following Sang Han
Hello everyone, How to do power sharing for unbalance MPPT? I use SG50CX-P2 and 1 no. SG12RT. For SG12RT, I use 1 string per MPPT. During simulation error message show have to use all the main and all the secondary input and later I ticked the secondary input is not used for this inverter. but still I cannot so power sharing. How to do the power sharing for this inverter? Thank you in advance for your support.
shkim joined the community
Hello Team, I am using V8.0.11 and trying to model Bifacial w/ Fixed Tilt Plane, Flush to Roof mount via Polygonal Fields - this is not compatible with bifacial 2D model - is this a bug or is there some way that I could model this irregular layout with bifacial (see snip of model)? I realize this flush to roof the bifacial factor will be very small, but the client is determined to confirm modeling this bifacial gain.. Any suggestions and thoughts are greatly appreciated, much thanks in advance! ie would converting to a Rectangular PV Array and trying to line up/match this jagged flush roof layout (as much as possible) allow the bifacial 2D model - or something else be a workaround? Thanks, Mike
Here's one way CCC could be incorporated into PVsyst, to enable more accurate modeling with standard hourly TMY datasets:
CarlosSolis changed their profile photo
Hello PVsyst Community, I’m a solar PV designer working on utility-scale projects and looking for an efficient way to import a 3D forest model into PVsyst. The goal is to perform accurate shading and horizon analyses, as nearby vegetation significantly impacts system performance. If anyone has experience or recommendations for importing realistic 3D vegetation or forest models into PVsyst—whether through SketchUp, terrain files, or other compatible formats—I would greatly appreciate your insights. Thanks in advance for your support! Best regards, Carlos
CarlosSolis joined the community
mazenalselwi joined the community
Hello everyone! I searched for documentation explaning better about the Albedo that is now available in version 8 to input in .MET files, but I didn't find any infformation. Can you please explain me better if the Albedo inputed in timeseries data would it be realted to albedo of the project, which is the albedo of the far terrain in front of the PV installation, or the albedo for the bifacial evaluation, that is the albedo of the ground below the installation.
Arjav joined the community
Indeed it seems a bit surprising that the global irradiance would be 0 for a few hours in the middle of the day, but indeed possible. Using another weather data provider, do you see similar drops in irradiance? If you import a weather file with missing data, these hours will be considered as 0 in PVsyst. -
Hello, I am currently faced with some technical difficulties while doing the simulation and would like to make an enquiry... I am trying to find the reflection data from the solar panels from the simulations, so that we are able to study how bright the reflection would be during different hours of the sun. However, from the advanced simulation, data related to reflection only comprise of ground reflection on front side and back side. Understand that PVSYST is not able to give the direct data for total amount of reflection, is there any other methods where we can do a self-calculation from the data's derived from the simulation? I tried doing some research and had the hypothesis that from the law of reflection, incident angle = reflected angle on smooth surface. So, using that as a basis, the total IAM loss could also apply to the reflected angle. Meaning the reflected angle would also have the same IAM loss however, after much digging, I found that that might not be the case.. So I am actually quite stuck and confused.. T-T My knowledge of this is really at the basic level so I could really use some help. Thank you
