	  mismatching night consumption at same AC capacityAndré Mermoud replied to mohaned's topic in Simulations Probably you have defined your transformer by a generic relative loss, i.e. proportional to the transformer nominal power. And this nominal power - evaluated by PVsyst on the basis of the PNomPV at STC, or the PNomac (this is your choice in the Project's settings) - has been changed in your different runs. This should not arise if you define an explicit transformer from the datasheets, the nominal power of the transformer will always remain the manufacturer's value. In this case the "generic" relative values will be updated as a function of this real Transformer nominal power.
- 2 replies
		- 3d shadings
- near shading 3d scene
	  PVsystCLI: Changing Simulation ParametersMichele Oliosi replied to Gustavo Pianovski's topic in How-to For most practical purposes, this is already available in the latest 8.0 version. Indeed, PVsystCLI has been made compatible with batch files. In other words, you can call a batch of simulations from PVsystCLI using a batch parameters file. You can find some more details on this page: https://www.pvsyst.com/help-cli/reference/index.html#run-simulation The command that you should look at is --batch-params-file
- 2 replies
		- 3d shadings
	Ilyas aitelasri joined the community
	seyed rasuol joined the community
	Weather file import not working. "The hourly data are not defined."mcolonel replied to LPeterson's topic in Meteo data I am having this same issue. I'm running 8.0.17 and will revert back to 8.0.1 - thanks LPeterson.
	  How can I import a quarter-hourly meteo file into PVsyst?Auriane Canesse replied to DiegoNav's topic in Meteo data Did you try to define the time shift as indicated in the error message? You should also check that you have input the correct time reference If the time shift information you input is not taken into account or if non of the time base work, could you please sent your csv data file, .MEF file and PVsyst version to support@pvsyst.com so we can have a closer look at your problem
	Jamescooperworld95 joined the community
	chanasith janngurn joined the community
	PVsystCLI: Changing Simulation ParametersGustavo Pianovski replied to Gustavo Pianovski's topic in How-to Do you have an updated estimate for when this will be implemented?
	mcsgchd joined the community
	How can I import a quarter-hourly meteo file into PVsyst?DiegoNav replied to DiegoNav's topic in Meteo data Thanks for your quick response Auriane! Now I have a problem inserting the .MET file, I get the following error: I've been searching for information and other people on the forum had the same problem when importing the file from "Known Format". When I try to simulate the project I get the following error that prevents me from simulating: I was checking if the data in "Monthly best clear days graph" was correct and if it seems to resemble the data in Excel. I've read that there's a problem with the known format import function in PVsyst, and with the “Convert UTC to local time” in the NSRDB viewer. I would like to know if the error continues to appear, since the forum page where I have consulted all this information is more than a year old, and where I can find how to convert from UTC to Local Time. Thank you!
	Michele Oliosi started following Como añadir una variable en el informe de Pvsyst and Electric layout
	@Yvano I see. Thanks for the clarification. Indeed, as mentioned by @André Mermoud the only way currently is to use the automatic attribution instead of the manual one to reach these overlapping modules. I will record this issue for future improvements.
	  Como añadir una variable en el informe de PvsystMichele Oliosi replied to Enzo Melgar's topic in Problems / Bugs Hi please make a new post in English or translate this one (including the title). Following the language rule will allow us to help more efficiently and also help other users 🙂
	Weather file import not working. "The hourly data are not defined."LPeterson replied to LPeterson's topic in Meteo data Following up on this, I reverted back to version 8.0.1 and I am no longer having this issue. So it seems like a bug was introduced at some point.
	Could you please explain why?
	LPeterson started following Weather file import not working. "The hourly data are not defined."
	When importing a weather file for a new project, I am getting an error that says "Invalid weather file: The hourly data are not defined." I am using the same process I have always used, where I define the coordinates of the site and then import weather data from SolarAnywhere (see screenshot), but not I am getting this error which I have never gotten before. I also tried using NREL/NSRDB, and I am getting the same error. Is this a bug? I just updated to version 8.0.17.
