Nils Lang started following About Interactive map not working
Indeed it seems a bit surprising that the global irradiance would be 0 for a few hours in the middle of the day, but indeed possible. Using another weather data provider, do you see similar drops in irradiance? If you import a weather file with missing data, these hours will be considered as 0 in PVsyst. -
Adeline joined the community
Alessia started following Different Backtracking Strategies for Morning and Afternoon
t Hello PVSyst team, I'm trying to import topology but it seems nothing downloaded well. Just looking white for few mins. Is it still having a bug or error?
Mahdi joined the community
SGI joined the community
sana11 joined the community
Charlie joined the community
Hi Eric, I checked and the partial shading calculations is not on. I have emailed the example project file as a follow-up. Thank you for your help, Evan - Earlier
