Elzed40 joined the community
Theo joined the community
Farkhi joined the community
MBU_3E joined the community
fabrizio joined the community
yamahaoutboards6 joined the community
Siddanth Gokuldev joined the community
Please remember that we are working in hourly values. And the thresholds according to the battery SOC may arise during the hour, so that the transition from an operating state to another one may arise during the hour. Therefore you can have a "Battery full" state at the beginning of the hour, and a discharge during the rest of the hour. However there is also a visual artefact because you are showing lines from the middle of hour to the middle of the next hour. In your first plot, at 13:30 you have unused energy, but no BESS discharge. At 14:30, you have BESS discharge, but no Unused energy. The intermediate lines don't have any meaning. - Earlier
