nurul joined the community
Maitha S joined the community
Mbelli Njah Fongha joined the community
kidsbikes34 joined the community
Are you saying that the (front-side) near shading loss would be lower if i modelled a bifacial system because these systems are more precisely modelled or defined, even though the near shading losses happen before any bifacial modelling in the loss diagram (and should be independent of whether the system is mono or bifacial)? - Last week
piterpal1988 joined the community
PabloCliment joined the community
Zaenul01 joined the community
Sorry, the albedo shading factor should be *~65% and *~48% during these times, not sure what happened there - Earlier
Thanks dtarin, it worked! -
That would be great. -
Hello everyone, I have a question regarding the use of PVsyst for performance modeling in the context of performance testing (PPI and EPI) as described in the standards IEC 61724-2 and IEC 61724-3. Can PVsyst be used to generate a performance model that is suitable for performance testing according to these standards? Does anyone have practical experience with this? Is it possible to use 1-minute measured data in PVsyst for this purpose or what is the minimum data resolution supported for imported measured data? Thank you in advance.
