matthewGrant joined the community
MOHAMMED ALHAJJ joined the community
MariusPostolachi joined the community
Kkp joined the community
Devajt joined the community
Khizar Musharaf joined the community
Sara joined the community
Muhammad Aqib joined the community
Ephraim joined the community
Dear JStief, This is puzzling, especially because PVsyst will average data to 1-hour steps anyway, meaning that the modeling should be identical. The first thing that springs to mind is that the 1-min, 5-min, and 60-min files are not simply related by averaging. In other words, if you average the 1-minute data, you won't obtain the 60-min data. Is there a chance to check that ?
