Indeed it seems a bit surprising that the global irradiance would be 0 for a few hours in the middle of the day, but indeed possible. Using another weather data provider, do you see similar drops in irradiance? If you import a weather file with missing data, these hours will be considered as 0 in PVsyst. - Today
Adeline joined the community
Alessia started following Different Backtracking Strategies for Morning and Afternoon
Mahdi joined the community
SGI joined the community
sana11 joined the community
Charlie joined the community
Neill joined the community
