  2. Hello, You can read about how to adapt you PVsyst simulation to a floating system in the following post: https://forum.pvsyst.com/topic/1346-how-to-adapt-pvsyst-to-floating-pv-systems/
  3. Hello Tyler, Essentially, the Global incident in the collector plane will be calculated for each sub-array for the assigned orientation (or possibly a mixed orientation). The GlobInc as the total result is an weighted average based on the Pnom PV
  4. Hello, You can use the lasso selection (Ctrl+Shift+L) to mark all the tables that belongs to the concerned orientation and in the "List and management if objects" window (Ctrl+G) you can change the orientation of all the marked tables.
  5. Hi, I am trying to understand the Bifacial gain for my system in terms of electrical output for each string. The simulation results gives me I (Array) which i think is total Imp of plant both including front and rear contribution and not on string level. I understand PVsyst follow one diode model for Bifacial module but still is there any way PVsyst providing the value of this rear side and front side Imp separately for each string.
  6. If I want to simulate FPV system in PVsyst, for the temperature coefficients Uv and Uc, how much should I insert for each value?
  7. Yesterday
  8. Hi Linda, I'd like to circle back to the original question, as I have a similar project with multiple azimuths and tilts, resulting in eight distinct array orientations. Since there is only one GlobInc value on the 8760, I am trying to determine how that GlobInc value is calculated. Is it a weighted average based on the DC capacity per each orientation? Thank you.
  9. Hi, thanks for the answer. My problem is that when I import the pvc file with the shading scene I do not know how to associate the different pitch to the two system sub-arrays. Like in this case, I have already created two sub-arrays in System design for the two pitch values, but how can I associate them correctly? If I click on one of the two group of the 3D fields, it highlights a mix of trackers with the two different pitch values.
  10. Yes indeed, one only other user reported this error. The error is indeed the unit's name, which should be MWh/year. With this the value itself is correct. I really don't know the origin of this error. I tried to secure some initializations, but I really cannot reproduce this problem, so that I can't be quite sure that it has been corrected. The user who had reported it cannot reproduce it, too. If you get this problem in a stable way, please send us you whole project, using "Files => Export project" in the main menu. Please send it to support@pvsyst.com.
  11. I have a variant of a project in which the 8760 file shows that E_Grid column is not reaching the defined "Grid power limitation" of 25 MW in "Energy Management" and yet there is some energy discarded as EGRdLim in the 8760 file. What makes it more confusing is that I'm copying from a variant that is working well, and just changing the orientation to domes. I'm attaching a capture of some of those cases. Any thoughts on what I may be missing? Thanks!
  12. Hi Greg, In PVsyst the grid-tied systems with storage will never charge the batteries from the grid. The non-zero values for EFrGrid are situations where PV generation and battery discharge together are not enough to cover the load, and therefore power needs to be imported from the grid. This typically happens at the end of the night and early in the morning when batteries may be discharged and PV generation is still low. It can also happen after a series of cloudy days that did not allow to fully charge the batteries.
  13. Hello, It seems to be linked to one of the new tolerances put in the new version that when the angle between your average orientation and at least one of your PV table is too high compared to the settings of your projects. To fix this error you need to increase this tolerance. From the main window of your project, click on "Project settings" at the top of the screen: Then you need to select the "Other limitations" tab and increase the value of the "Maximum orientation difference for defining average (spread) orientation" parameter: Once the value has been increased the error should disappear.
  14. Hello, The clearness index will be evaluated and compared with the clear day model for the same time period. Thus having only a few months of data will not be an issue. If you compare the data for 2025 with data for 2024, are they similar or are indeed the values for 2025 much lower?
  15. Hello, Indeed the workflow would be to precisely define the coordinates for where the site, define the MEF file and run the conversion of the data. If PVsyst suggest a time shift, go back to the MEF file and define the indicated time shift and run the conversion again. If the issue persists, please send your data to support@pvsyst.com and we can have a closer look.
  16. Hi, I am simulating a large-scale ground mounted PV project with fixed tilt orientation. Due to the slope of the terrain, each PV table has a slightly different orientation. When importing the H2P file, I get the error as shown below. In Version 7, I remember I was able to adjust the tolerance in the Orientations Management tab. That seems not possible now. Could you please let me know how to resolve this? Many thanks!
  17. Hello, This is possibly by creating two "orientations". Thus create one orientation for each pitch (even though they have the same orientation) and assign the bifacial parameters individually for each orientation.
  18. Hi, you can export an Output File with any relevant parameters through the Advanced simulation window.
  19. Last week
  20. Good afternoon PVsyst team, My name is Nuno and I work at Universal Kraft as a PV Design Engineer. I am posting this message to report a bug that our technical team came across with this new version of PVsyst (8.0.12). When simulating the hourly (energy) production profile, the PVsyst report (.pdf) shows the energy produced in kW/year which must be kWh/year and, besides this, the value presented has 3 order magnitude difference. This means that the value presented in the PVsyst report (kW/year) should be MWh/year. Could you please verify/confirm if this happening with other costumers or if this is a problem that only our team is facing. Thank you so much for your support. PS: I tried to upload the reports but the forum is returning an error (Error code: -200)
  21. Hi All, I am currently using PVsyst version 8.0.9 and in the 3D scene, I am trying to export a .pvc file created with PVcase in which there are two different pitch values. While activating the bifacial features, I encounter an issue that does not allow to compute the simulation since the pitch is not sufficiently homogeneous. With PVsyst 8.0 is there a way to simulate in the same variant bifacial system with different pitch values? Am I trying to get the simulation in one single variant and not in two variants (one with a pitch of 9m and the other with pitch of 12m) and do the post-calculation. The reason is that I am trying to identify the impact of shadow casting of wind turbinesand those wind turbines are near trackers with both 9m pitch and 12 m pitch. Below, there is a screenshot of the problem. Any help is really appreciated. Best regards, Vinh
  22. Dear Greg, If you don’t want to import energy from the grid, it’s considered a stand-alone project. I suggest running your simulation as a stand-alone system. In a grid-connected project, the grid supplies energy when the system can’t meet the user’s demand. See my screenshot below: Regards,
  23. Good afternoon, I have created a new SIT file and I want to make a customized MET file with another source file. While making the MEF file I have selected -1 Time shift, with universal time. Neverthless I am receiving a message that I should specify an Hour shift of -1 in the format file and reimport. How can I manage to change the shifted time so it is complying with the Clear Day model? Kind regards
  24. Hello, I wanted to create a custom imported meteo file for a location in Germany for 2025. The real data is available from Jan, 2025 until today. As I import the weather data I get an error due to clearness index of best days is way too low with respect to celar day model. Is it because PVsyst’s clear-sky model expects the year to include summer months (June–August), when irradiance and clearness index are highest. If my dataset ends in May, PVsyst looks for the “best” days in spring or winter — which naturally have lower solar angles and less irradiance, even on clear days. So even the “best” days don't look clear enough compared to what they should be. Or can it be due to a different issue? For the same location I could create custom imported files from 1993-2024 so only 2025 gives the error. Thanks a lot in advance!
  25. The multi-MPPT feature and how to configure different sub-arrays to precisely define your system is explained in the following youtube tutorial:
  26. OK,thanks.
  27. No, due to by-pass diodes, the hot spot situation is not supposed to arise in normal operation.
