MOHAMMED ALHAJJ joined the community
MariusPostolachi joined the community
Kkp joined the community
I was testing PVsystCLI normally, and suddenly the following error started to appear: The license file "C:\ProgramData\PVsystCLI\PVsystCLI.lic" is missing. You can run "lic-activate" command to activate your license. When I run the command PVsystCLI lic-info, I get the following information: The license file "C:\ProgramData\PVsystCLI\PVsystCLI.lic" is missing. You can run "lic-activate" command to activate your license. Status: TRIAL Remaining days: 17 Remaining executions: 208 Host ID: HARDDISK=0000_0000_0000_0001_8CE3_8E05_00AE_DC3E., ETHERNET=0A0027000004||70A8D3D028D0||72A8D3D028CF||70A8D3D028CF||70A8D3D028D3||B44506AB2282, WIN_PRODUCT_ID=00342-43291-73682-AAOEM, BIOS=752V6R3 It clearly says that my Trial license is still valid, but the CLI doesn’t run any simulations — it just stops with the “license file missing” error. I didn’t change anything in my system configuration, and this issue appeared suddenly. What should I do to make PVsystCLI work again during the trial period? - Last week
Devajt joined the community
Khizar Musharaf joined the community
Sara joined the community
Muhammad Aqib joined the community
Ephraim joined the community
Mickael BLEIN joined the community
REDSTAR SOLAR joined the community
Dear JStief, This is puzzling, especially because PVsyst will average data to 1-hour steps anyway, meaning that the modeling should be identical. The first thing that springs to mind is that the 1-min, 5-min, and 60-min files are not simply related by averaging. In other words, if you average the 1-minute data, you won't obtain the 60-min data. Is there a chance to check that ?
