Dougal joined the community
alexis joined the community
James Barry joined the community
xander joined the community
abdullah ali joined the community
matthewGrant joined the community
sundance-juliet joined the community
MOHAMMED ALHAJJ joined the community
Yes this is what I meant ! However, the differences seem to be small, I do not think they would account for the transposition difference. Another possibility that could exacerbate the effect of small GHI differences could be if DHI was not included in the file or not used at import ? Is there a chance you could send the weather data files (MET) or the raw data over to support@pvsyst.com? This would make the analysis a bit simpler.
