Miguel G joined the community
Edson08 joined the community
Jingyi joined the community
Edlian8142 joined the community
Mikhail123 joined the community
Lekianar joined the community
Do I have to used Monthly normalizations in order to input the daily hourly profile for every month? Seems like they still using the same Load Profile and change the values for each month based on how many days in the month. I want to input the profile for every month without them connecting like this. - Earlier
