Edlian8142 joined the community
Mikhail123 joined the community
Lekianar joined the community
Bipin joined the community
Mark Russell joined the community
Paul Gaudry joined the community
Hussain Hamid joined the community
This is explained in detail in the help https://www.pvsyst.com/help/project-design/array-and-system-losses/ageing-pv-modules-degradation/index.html?h=ageing The LID degradation occurs in the first hours of the system operation. It is simply treated as a diminution of the PV module efficiency, whatever the operating year. In your case it should be specified as null. This curve is a warranty for each individual module. It does not describe the average ageing behavior of the PV system.
