I have just run a simulation for a ~4MWp array, with the terrain model - including DTM and custom mesh-based objects - imported from Helios 3D and have found that if I switch on shadow casting on the ground terrain the shading model goes a little off-piste.
Switching off the ground shadow casting, so including the array self-shading (with string effects) and other near-shading gets a much more sensible result.
Oddly the hourly file seems to give a more realistic result, and the E_Grid values don't match the report!
Any ideas? I think it's a bug, but I have emailed the PVsyst support crew copies of the project for a deeper assessment.
Thanks,
... and with it enabled
Iso-shadings without ground shading...
  • 2 weeks later...
Yes, I just found the same thing in version 6.43. I turned on shadow casting for a complex ground object and the shading seems buggy (extremely high and intermittent over time).
