The latest guidelines from SolarEdge indicate that string sizes may be up to 15,000 w. PVsyst V 6.43 does not allow oversizing. What parameters do I change to increase the allowable wattage on a SolarEdge optimizer string?
Thanks in advance
Solaredge has not shared theid latest Guidelines with us.
However I don't understand well which limitation you are speaking about. Please give a screenshot of window in error, and the exact error message.
  • 1 month later...
A current workaround to this limitation is to design shorter strings, just for the PVsyst simulation (in practice you will install with the over-sized strings).
This will have no effect on the simulation.
So for example: you want to design an SE27.6K inverter with 3 strings of 22 power optimizers (each optimizer connecting to 2 modules in series, so the result is 66 power optimizers = 132 modules). PVsyst perhaps limits the string length to 18 optimizers, so you could instead specify 6 strings of 11 power optimizers, giving you the same result (66 power optimizers/132 modules).
Any mathematical combination will work, as long as you get the number of modules you want.
See the attached image.
  • 6 months later...
Has there been any movement on extending the power optimizer definitions inside the software? I can not go beyond 19 with a 72 mono when design guidelines define the use of 20.
  • 4 weeks later...
  • 1 month later...
