Tavasez Posted March 18, 2016 Posted March 18, 2016 Hello, everyoneWhen i make my 3D model, it gives me warning "The orientation of the collector plane for shadings doesn't match the one defined in the Orientation parameters of the PV array" and "You should correct the shading scene or update the orientation's parameters". The things is that in Orientation i didn't give the optimal filed parameteres that the program gave me because i don't like the dispolsal of the panels. Instead i gave the program a different azimuth. I guess that is the problem. So can i make the shading factor tables active with my prefer parameteres or i must insert the correct ones?
André Mermoud Posted March 20, 2016 Posted March 20, 2016 The parameters (tilt, azimuth) should match between the "Orientation" part and the 3D shading scene of course. Wanting to do otherwise doesn't make sense.
Tavasez Posted March 20, 2016 Author Posted March 20, 2016 Yes, that was my mistake and i corrected that but i still get the warning "The object CommentEdit is very near to the PV array Shed field" and i can't understand the meaning of it?! Sorry but english is not my native language :)
