Now I am using Pv Syst 6.41
I am trying to an existing variant run with Perez model to run alternatevely with Hay model. Althou I change in Preference > Physical models the report still mentions Perez and the result does not change.
Do I have to try something else ?
I checked in 6.39 again and I had no problem chamging the model.
If you read the instructions on the dialog in "Preferences", you will read this:
"This choice is for use outside of a project (tools, database and new projects).
The model choice for actual simulations is now defined in the project's parameters".
The project's parameters are defined under the button "Albedo & Settings" in the Project's dialog.
Sometimes reading the instructions in PVsyst may avoid loosing time...
