ckoessler Posted August 12, 2015 Posted August 12, 2015 When trying to import some of my meteo data via PVsyst standard format, decimals are not always considered. That should not be a format issue car for some of my files everything is working fine.But 5 of 10 years were not imported well. Is there a mail, I can sent a sample to, so that you could test data yourself (can't join the .csv)? The example concernes data from 2011. I also had problems with 2008,20102013 and 2014.Do you know this problem? How can I handle it?Thank you for your help.Best regards
André Mermoud Posted August 17, 2015 Posted August 17, 2015 This is not a problem of import, but just of display on the tables. The values in the program are not truncated. However decribing hourly values of irradiance with 0.1 W/m2 resolution doesn't make sense, as the measurements have a much higher uncertainty. The same holds for ambient temperatures specified with 0.01°C. Did you ever try to measure an ambient temperature with a thermometer ? Even with 1°C resolution the value will not be stable over one hour !NB: The rounding errors of measurements are always randomly distributed: the variance on several measurements goes with 1/sqrt(n) (n = number of measurements). For one year (8700 values), this becomes 0.01 times your uncertainty interval.
