Sylvain Pepoli Posted March 2, 2015 Share Posted March 2, 2015 Some companies use a network environment to install software on end-user computers.The basic command line to install PVsyst using msiexec is the following one :msiexec.exe /i "PVsyst6_3_4_setup.msi" /qnThis command will perform a silent installation of PVsyst, upgrading any other previous version automatically.But you might also want to perform a parallel install, which you can do by adding the following parameter to the command line :msiexec.exe /i "PVsyst6_3_4_setup.msi"/qn UPGRADE=NOThis will perform a silent parallel installation !NB : The /i parameter is used when the command is executed on the computer where PVsyst will be installed, depending on the environment you may have to use /a, please refer to the Microsoft documentation for further information. Link to comment Share on other sites More sharing options...
