Some companies use a network environment to install software on end-user computers.
The basic command line to install PVsyst using msiexec is the following one :
msiexec.exe /i "PVsyst6_3_4_setup.msi" /qn
This command will perform a silent installation of PVsyst, upgrading any other previous version automatically.
But you might also want to perform a parallel install, which you can do by adding the following parameter to the command line :
msiexec.exe /i "PVsyst6_3_4_setup.msi"/qn UPGRADE=NO
This will perform a silent parallel installation !
NB : The /i parameter is used when the command is executed on the computer where PVsyst will be installed, depending on the environment you may have to use /a, please refer to the Microsoft documentation for further information.
