claudio.davalle Posted October 20, 2014 Posted October 20, 2014 Hello,I am running PVsyst 6.26.I have some questions about creating a Regulator/Converter Device for Pumping System.1. When I create a new model, PVsyst suggests as File name "New.RLT". Shouldn't it be "New.RLP"? Have I to change the extension manually?2. I need some clarification about Output (Pump driving) data (MPPT converter tab). Are nominal/maximal quantities referred to inverter output (AC - connection with pump motor)? Can I consider:Nominal output voltage: AC rated output voltage of inverter?Nominal Output power: rated output power of inverter (the rated power of the motor to be connected)?Maximal Output Power: the maximum output power (i.e. Irms x Vrms x SQRT(3), in kVA?Can you please give me better explanation?Also I have noticed that the nominal Output Current is automatically calculated as Maximal Output Current/Nominal Output voltage, as if it was a DC output stage. But I have a MPPT-AC inverter!Therefore, I have seen that, when I try to use the above defined regulator inside a project, (Pumping System definition - Further system characteristics), anytime I enter there, the Regulator / Power conditioning device is always set to Default regulator. Anytime I have to uncheck "Default regulator", and choose it again, even if I save the current variant. Is it a bug or it's OK?Thank you in advance,Best regards,Claudio Davalle
