Hi, Im using PVsyst V6.30 and I did a simulation with 2-axis tracking system.
I read the topic about the shading loss on diffuse: http://forum.pvsyst.com/viewtopic.php?f=30&t=694 but Im still confused. The "near shading" in my simulation is very high, 10,7%. Is this normal? I noticed a big shading loss on diffuse and albedo. Here are some shading loss on my system:
The PR of my system is 69,8%. I think this is a low PR for tracking system. What do you think? These values are normal? Any recommendation?
Thanks!
Hi, I repetead the simulation with just 1 tracker to avoid mutual shading and I still have 10,7% of near shading. So I decided to start a new project with the same modules, same inverter and same configuration as before but in a different location.
First simulation I placed just 1 tracker and chose Canada for my location using meteonorm 6.1 station;
Second simulation I placed just 1 tracker and chose Sao Paulo for my location using meteonorm 6.1 station.
In the fisrt simulation the "near shading" was 0,1% which is good for a tracking system.
In the second simulation the "near shading" was 10,7 which is bad for tracking system.
Do you know what am I doing wrong? Do you know if the location can affect so much in the near shading calculation? In both simulations, my near shading scene is empty. There is just 1 tracker in the scene!
  • 2 weeks later...
This problem happens on the southern hemisphere for two specific tracking cases:
- Two Axis
- Vertical Axis
It is a bug that is caused by a wrong sign in the calculation of the diffuse shading.
This bug has been fixed for Version 6.31.
