purnaanshg Posted August 29, 2014 Posted August 29, 2014 Hi,I am trying to figure out a way to use multiple PV modules (Eg: Renesola 250W, Trina 230W, Canadian 300W) to design one site. These panels will be constitute separate strings (Eg: X strings of 20 Trina modules each, Y strings of 18 renesola modules each etcetra)Our inverter architecture is distributed with Master/Slave functionality and all these modules will be connecting to one island of "X" inverters with 1 master and "X-1" slaves.Can you please suggest a way to perform the simulation.ThanksPurnaansh
André Mermoud Posted August 30, 2014 Posted August 30, 2014 This configuration is not possible with PVsyst. The master/slave functionnality is only useable within one given sub-array. This limitation is quite understandable: if you connect your inverters in Master/Slave mode, all the PV sub-arrays will be connected together as a same array. PVsyst (and the best practices of PV) cannot manage heterogeneous arrays, i.e. array with different modules and/or different numbers of modules in series.Be careful with your strings of 20 Trina and 18 Renesola modules in parallel: the operating voltages will not be the same, you will have a significant mismatch, and you can get double Maximum power points, with the risk that the inverter chooses the lower one.
