AlanKnudson Posted June 17, 2014 Posted June 17, 2014 I am trying to model the peak 15 minute load output per month for a 1 MW system in Utah. How would i go about doing this? The compensation structure in utah is a demand and usage payment for large (1-3 MW) installations. I wasn't able to produce accurate simulations on SAM, any suggestions?
André Mermoud Posted June 18, 2014 Posted June 18, 2014 You cannot identify peak values over 15 minutes interval, as PVsyst only performs simulations on 1-hour time step data. However an indirect way would be to identify the peak irradiance in your original 15-minute meteo data. As the output of a PV system (without Power limitation) is very linear with the input irradiance, you can calculate the ratio E_Grid/GlobInc for a similar hour in your hourly data, and appliy this ratio to the 15-minutes peak irradiance.NB: you can get a table of the maximum hourly values for each month and each hour of the day in the results "Tables" / "E_Grid hourly averages". Here you can choose Maximums instead of averages.
